08 343 excalibur motor with 1100 well maintained hours. No salt use ever.
Recently having hesitation and rough idle with black smoke at idle.
Just did a PM which included new fuel filters, recommended plugs, cap and rotor, plug wires, oil and filter change. (even bought a second cap to try to be sure I didn't get a bad one).
Still having same problem and after going one by one on the new spark plugs (replacing with a new one to be sure I didn't get a bad one) I find one cylinder with a white basically looks un used porcelain. Other plugs are light black to dark brown. Apparently that cylinder was on the compression stroke when Removed the plug as I got a strong hiss of air when I loosened the plug. (engine hadn't been run since Sunday (24 hours). I don't have a compression tester.
Small dash temp gauge stopped working around same time but digital display in tach reads normal temp when warmed up (150-160). Dealer says as long as digital gauge works that it is not the problem.
Has anyone ever had an injector go bad on one of these?
No codes stored when engine checked (not running).
Anything else? I'm stumped and took it to the dealer ..Sadly hourly rate is near $150
