Winterize tips needed sport 1999
  • tgray015
    • Apr 2006
    • 9
    • Cleveland, Ohio
    I'm trying to winterize without running water, what are the best ways to handle this and or can it even be done. I have unlimited access to water. I have seen some people do this but have never gotten any details.. Any help would be appreciated, I also if possible would like to not take off my thermostat. I do have electricity and a little pump i have used in the past. I was going to try taking the intake hose off and simply put this is bucket, does this work?? I normally just use fake lake with a hose and hadn't had any problems but was trying to not have to bring boat home from lake. Thank you
  • Quinner
    • 2246
    • Correct Crafts
    Drain everything including shower and heater if so equipped, once drained you can either back fill with antifreeze per the owners manual or suck up 3-4 gallons of antifreeze, no need to run water.
    • Quinner
      • 2246
      • Correct Crafts
      Trans cooler, be careful on that one
      • Skidave
        • 697
        • York, PA
        Raw water intake strainer and hoses going to raw water pump.
        Sent from my SM-J337V using Tapatalk
