Figured out my Hesitation Problem on my 99 GT-40
  • 1998CanadaNautique
    • Jun 2006
    • 43
    I took the fuel pump off and cleaned off the screen, It was very plugged with debris. Then I pulled the line out of the fuel tank and it was also just about plugged off. Then I pulled my fuel tank out and cleaned it out and put it back in. I tested the fuel pressure before and it was very low, now its back to normal. My only advice is when useing Jury Cans you should always use a funnel with a screen.
