Hole Shot
  • mopowpow
    • Jun 2006
    • 19
    Hole Shot
    Anyone else notice the lack of hole shot in their 2006 196? OUr 2006 is a dog compared to our 2005.
  • MHayes
    • Aug 2004
    • 830
    • Roswell, GA
    RE: Hole Shot
    Is there a difference in props between the 2 years?
    2001 Air Nautique
    • mopowpow
      • Jun 2006
      • 19
      I'm not sure about the prop, will check it out. We are suspecting the throttle by wire. The 200+ men are really complaining. I even notice a difference at 150 lbs. It has a hole shot worse than our old Malibu.
      • SGY
        • 990
        We noticed the same thing with the Malibu Response LXi for 2006. Much softer than the 2003 RLXi we use. We also suspect the TBW set up.
        • pj
          • Oct 2003
          • 323
          • Rochester, MN
          • 1991 SN 1996 SN
          Maybe it has something to do with the throttle by wire. I've noticed it has the same amount of power, just takes it a second to realize you ordered it.
          Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
          • mopowpow
            • Jun 2006
            • 19
            We found out that it is the TBW. IT doesn't respond as quick as by cable. Are there any adjustments for this? Will they improve it for 2007? If not we might keep our 2005 instead of trading it for a 2007.
