My boat keeps beeping with a low oil psi signal to the gauge and the alarm in the big gauge tack or ??? cant remember, oil psi is fine as verified by running a manual gauge into the oil filter housing, any idea which sensor it is there are 2 of the down by the oil pan on the right side of the motor as viewed from the rear of boat.
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Which engine?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
So trying to diagnois the problem of my oil psi gauge and the readout in the tack the digital readout if I take a test lead and ground out the wire on #9 nothing happens to the gauge or readout but if i ground out #7 the gauge pegs and the readout shows 80 psi.
Am I correct to assume both units run of the oil sensor (7), not the switch (#9)
Maybe should get both cause it is **** to get at.
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Yes, both will read off of the sensor (7), not the switch (9). The switch would only be used to activate the check engine light.
I wouldn't bother replacing both. Just replace the sensor and you should be all set.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
