So I have reached out to NP to see if they can be of help, but I have a couple of issues with the replacement kit and not sure what to do.
1st is the Speedo doesn’t work, it bumps when the ignitions kicks on, but never hovers above 1 MPH to acquire the signal. I have double checked with wiring and it looks correct, and the switch is on 2.
The next issue is that my water and air temp read about 20 degrees under what they actually are.
The next and final is that my instrument lights don’t light up when the Nav Lights are on.
Again I’ve checked just about everything I can think of, but not really sure what else to do. My main concern is the Speedo the rest I can live with if need be.
Any thoughts would be appreciated!
