Sante shore station
  • Beetle0310
    • Jun 2019
    • 66
    • Joliet, il
    • 2011 sante 210
    Sante shore station
    Anyone have any insight into good shore stations for a 2011 sante 210?
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    120" 10,000 was what we used
    Ian S
    • Cadesun
      • Aug 2007
      • 99
      • Lake Geneva, WI
      • 2013 SAN 210 TE,,, 1998 Super Sport - sold
      I forget the width but I use a 5,000lbs lift for my 2013 210. I just make sure to get it in the water a bit before loading people onto it and make sure my ballast tanks are empty before lifting it after use.
      • Beetle0310
        • Jun 2019
        • 66
        • Joliet, il
        • 2011 sante 210
        Awesome thanks for the advice. Someone I talked to had an inboard boat on a 4500 but I dont think thats enough, looks like dry weight of my boat is almost 4200, add fuel and you're there at 4500 or more.
        • Cadesun
          • Aug 2007
          • 99
          • Lake Geneva, WI
          Agreed. I even feel like I am pushing it with the 5,000lbs and would never go lower than that. There are a few inboard ski boats on my lake with smaller lifts but that is apples to oranges. Even my old Super Sport was a much different beast than these newer (bigger and heavier) boats!
          • Beetle0310
            • Jun 2019
            • 66
            • Joliet, il
            • 2011 sante 210
            Looks like youre another chicagoan...where ya boat at? I have a place on apple canyon lake
            • scottb7
              • Aug 2011
              • 2198
              • Carson City, Nevada
              Hard to say how over engineered these things are, and it may vary by brand. I have had my 2014 g21 on a shoremaster cantilever 5,000lb lift for 2 years....zero problems. And we use it quite a bit, and lift with 3 or 4 guys in the boat.
              • Evening Shade
                • Apr 2015
                • 1295
                I don't have any specific advice on shore stations, but I have some good advice on boat lifts in general.
                DO NOT skimp on weight limit just to save a few hundred dollars. You will be sorry if you do. If you are buying a new lift, the difference in price of 5000# lift isn't that much more than a 10,000# lift. Always buy a little more than you think you need.
                With a 10,000# you won't have to every worry about weight with your 210. You won't even have to drain the ballast. Down the road, if you decide to upgrade your 210 to a G23 your all set if you buy a 10,000# lift. If you buy a 5000# lift and get a G23 your going to have to modify your lift or buy a new lift with a higher weight limit. Either way you will wish you went with the bigger lift in the beginning.
