Oil Pan Replacement 2004 PCM Excalibur 330
  • cgodfrey
    • Oct 2008
    • 4
    I have a 2004 Ski Nautique 196. Last week I found oil in the bilge and determined that the oil pan had rusted though around the drain plug. Spent the weekend getting everything unhooked to pull the engine and replace the oil pan. Are there any other maintenance items I should consider doing while the engine is out?
  • Gbracer
    • Dec 2018
    • 83
    • Langley BC
    • 2015 G25 550
    not really you might want to replace the oil pump but exerything is just optional while in the bottom of engine,, hoses that are hard to get to would be money well spent,
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      I think I would also replace all the fuel lines on a 2004.....you don't need the engine out to do that but it would probably be easier to complete with engine out
