I'm in the market to replace both batteries in my 2017 G23 and I wanted to do some research on compatible batteries. Can anyone tell me what Group Size battery I need and a good deep cycle battery they would recommend?
- May 2013
- 2795
- Smith Mountain Lake, VA (Craddock Creek area)
- 2017 G23 Coastal Edition H6 | 2001 Sport Nautique | 1981 Ski Nautique
The reason I'm posting a Mantenance/Tech question under General Discussions is beause I received no responses under the Mantenance/ Tech section so here we go again. I want to replace my 2 batteries in my G23 2017 can anyone tell me if they are group size 31 or group size 34 M batteries. I'm thinking they are one of these sizes but I'm not entirely sure.
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
The only specs I can find are in the PCM manual. They just say 650 CCA minimum. Since the G uses battery boxes, anything that will fit in the boxes and meets the CCA requirement should be fine.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- May 2013
- 2795
Originally posted by NautiqueJeff View PostThe only specs I can find are in the PCM manual. They just say 650 CCA minimum. Since the G uses battery boxes, anything that will fit in the boxes and meets the CCA requirement should be fine.
It’s just boxes sitting inside the hull correct? I’d get Group 31 batteries and worst case you have to buy a couple new boxes. They aren’t expensive and that way you have the largest capacity available. If i has to guess they are Group 27 factory, but if they are 29 then the boxes will be large enough to fit 31s.
Sent from my iPhone using PLT NautiqueJason
All black 2003 SANTE
-- Southern Fried --
- May 2013
- 2795
Originally posted by core-rider View PostIt’s just boxes sitting inside the hull correct? I’d get Group 31 batteries and worst case you have to buy a couple new boxes. They aren’t expensive and that way you have the largest capacity available. If i has to guess they are Group 27 factory, but if they are 29 then the boxes will be large enough to fit 31s.
I'm looking to get two of these Group 31 AMG Marine batteries from Sam's Club because they are a good deal and have 800 CCA. The lenght of the battery is 12.9 inches so I hope they fit into the stock Nautique battery boxes, if not like you say I can just buy two larger boxes.
https://www.samsclub.com/p/duracell-...lp_product_1_9
- May 2013
- 2795
Originally posted by scottb7 View Postok, could be me, but i would NOT do that...if the fiberglass has an indent for the boxes you can't just "but a couple new boxes"...
i know how it is when you just want to get something done. but i would just wait until you get the boat back or unwinterized or whatever.Last edited by GMLIII; 02-06-2020, 07:47 PM.
To the OP... I’ve always had Interstate batteries and they’ve been very good to me. My boat will be 17 years old this season and I’ve only replaced batteries twice. They’re affordable and you can sometimes get cosmetic blems for a discount. If you take care of them they will last!
- May 2013
- 2795
That’s why I kinda asked if they were just in boxes. If there is some sort of depression that limits the box sizing, then definitely measure before buying! I had to cut rather large holes in my boat to add larger and more batteries. Overall it was a project I love and was very useful/necessary, but not everyone will want to go through the effort.
Charger will help take care of them by desulfurization of the plates.
If you go AGM make sure you get a good charger that specifically states it's compatible with AGM batteries. I'm a big fan of AGM batteries but they do have different charging requirements than lead/acid batteries.
- May 2013
- 2795
Originally posted by bturner View PostIf you go AGM make sure you get a good charger that specifically states it's compatible with AGM batteries. I'm a big fan of AGM batteries but they do have different charging requirements than lead/acid batteries.
