Gel Coating Tent with Space heater
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • Steamboat Springs Colorado
    • 2003 210 SANTE
    I have prepped my rear compartments of my 2003 SANTE (removing carpet and glue and sanding down)
    I am ready to use a crushable Gel Coat that I have already tested .
    My shop stays at 50 degrees with no heat source here in CO......so I created a tent over Front to tower to rear with compartment lids open...keeping the tent 4" plus away from flooring.
    Manufacture says its safe to use a electric space heater to keep continuous temp in the tent for warming up and curing overnight....but recommended not to mix hardener and resin in the tent.
    I am concerned about the fumes and is this going to blow up with the space heater.
    What are peoples thoughts on this....and more importantly, has anyone done this system before? I have checked online for hours finding no negative thoughts....but double checking....triple checking...and quadruple checking....to make sure I will be safe, and my shop.
    Thoughts?
    D
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • 2003 210 SANTE
    4ft above compartment lids....typo
    • Rockymtnsurfer
      • Nov 2017
      • 404
      • 2003 210 SANTE
      Done...used radiant water heaters
      • Nautiquehunter
        • Jun 2008
        • 2080
        Wait a few weeks for warmer weather?
        • Rockymtnsurfer
          • Nov 2017
          • 404
          • 2003 210 SANTE
          Have you seen where I am from? 8700 ft in the mtns......it won't be above 38 at night until June
          • Nautiquehunter
            • Jun 2008
            • 2080
            Sorry it was in the 80's here I guess I guess I forgot what its like living in the cold?
            • Rockymtnsurfer
              • Nov 2017
              • 404
              • 2003 210 SANTE
              Im jealous.....high of 32 yesterday here
