Took the boat out a couple times this weekend, and the center ballast was always filling up to full. No pumps running and all seacocks shut off. No water in the bilge area either. Anyone had experience or any ideas to stop this?
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
In 2003, there were the helm control valves, that really didn't do anything. They just controlled the flow-rite valves, which were very ineffective. When you say the seacock is shut, do you mean that, or did you close the manual seacock down in the bilge? If you closed the one in the bilge, I would have that replaced right away.
If you want to read a book about this particular setup and the issues associated with it, check out this thread:
https://www.planetnautique.com/vb5/f...ballast-valvesI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Jan 2017
- 252
- Nashville, TN
- 13 Super air 230 Team Edition 03 Super Air 210 Team Edition - Sold 88 Mastercraft TriStar 220 - Sold
I will take a peek at that today thank you for the info!
So I have the 3 manual switches under the dash, and then also the 2 in the engine compartment. The 3 under the dash are set to closed, and then 2 in the engine compartment are set to closed as well. Only the center is filling by itself, but it is the factory hard tank. The rears are wakemakers bags.
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
There should be three. I can't remember if the third is in the engine compartment or in the floor access in the center of the boat.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
