2007 Super Air Nautique TE Dead temp, Tach, and oil pressure guage
  • bareh1
    • Mar 2020
    • 1
    • 2007 Super Air Nautique 220 team
    My starter died early this year changed it out. Also the main 40 amp fuse was blown, new starter installed changed out relays forw and have since installed 2 new batteries. Opened up the dash no loose wires or corrosion on harness connections. The Tachometer digital read out works for voltage but shows no hours for boat temp or pressure. perfect pass works fine. The volt meter guage clicks and doesnt light up with lights but digital on tach shows 12.9. I checked the Faria Box cleaned connections no corrosion internal. I am going to Add a ground wire to each guage see if it helps voltage drop only reading 8.4 volts at the end of series on the harness. Any suggestions would be helpful.
  • Stevemo14
    • Apr 2019
    • 691
    • Columbus, OH
    If your gauge setup is like mine, then all the gauges are daisy chained together, and if you have one bad gauge it can effect the rest. I don;t think the Tach LCD Screen would cause the issue, but one of the 3 gauges you mentioned are probably bad, and if you replace it the rest might just work.
    • Briano123
      • Apr 2020
      • 2
      • Texas
      • 2003 Ski Nautique 216 Sport
      Steve,
      i saw an old post you had from june of last year on a set of original gauges. Would you still have them and want to sell? or are they already gone?
      please let me know.
      thansk,
      Brian
      • crimedog
        • Feb 2012
        • 40
        • Huntsville, AL
        I've got a whole set of 07 gauges if you need them.
