Has anyone ever used a DC inverter in a G23? Do you know the max wattage I can get and not pop the cigarette lighter plug fuse?
Originally posted by wrut View PostHas anyone ever used a DC inverter in a G23? Do you know the max wattage I can get and not pop the cigarette lighter plug fuse?
20 amp (240W) is common in a lot if boats.
I tried to run a laptop on DC to 110V AC converter and it did not work. I had to run a good size cable directly to the battery and fused it with a 40A automotive in line fuse.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Originally posted by Peter6000 View PostLook up the fuse/breaker size multiply the amp's by 12 and you have you a absulute maximum, I would stay 20% below.
