I have a recently acquired 2002 Super Air Nautique. While poking around today, I discovered the front bilge pump is missing. The strainer is there, but no pump, no wiring, no hose. Assuming I have to buy some hose and run from scratch, how much hose do I need, where does it exit the hull, and how should this hose be routed? I presume the wiring comes directly from the switch? Am I going to have to remove the gas tank to do this work?
Thanks for the input.
