GT-40 - PerfectPass Install - Lost throttle in reverse
  • Liamfm
    • Aug 2017
    • 74
    • Vermont
    Hi, just installing a perfect pass on my 97 Sport. Things seem to be working okay with the PP (driveway test), but I've lost the ability to throttle in neutral, and the ability to throttle in reverse. To do the install I did pull the throttle cable up into the helm quite a bit to use it as a snake. Not sure if something came disconnected it that?
    Any advice on where to start would be great. In gear I do get throttle (in forward).
    Also, it does seem to want to come back down to a high idle (about 1050) rpms. But I think I can troubleshoot that after I get this solved, I'm guessing by adjusting the barrel nut at the throttle on the engine (lengthening / shortening the travel of the stock cable).
  • Liamfm
    • Aug 2017
    • 74
    • Vermont
    User error... I think I accidentally twisted the throttle cable a bunch of times, thus unscrewing it from the throttle control at the helm. Problem fixed!
