Sad times on Lake washington...
  • SatherG230
    • May 2018
    • 87
    • MN
    • 2012 SANTE 230 w/ NSS
    Not sure if I am missing something here, but the original post was about a major vibration even though your prop appears to be okay. Did your dealer determine that it was a software issue or do you have an unrelated issue with software?
    • ducatidesmo
      • May 2019
      • 116
      • Sammamish, WA
      • 2018 230
      This is why I shouldn’t write posts in the middle of the night. Yes this issue is resolved. Prop change. Sorry guys.
      I’m having a problem with my Linc Panoray screen now . Won’t turn on if the battery voltage is greater than 12.8, or interestingly enough, if it has sat for two days the first time... Workaround is give the battery some sort of draw, in this case the only thing I can do is turn on the blower. Turning on the motor is one **** of a draw, but then it starts to charging the system....
      We’ll see what happens.
      • SatherG230
        • May 2018
        • 87
        • MN
        Those props can be finicky! Good luck with your Linc issues!
