Just installed perfect pass in 08 sv211. When I turn the ignition on without starting the CEL comes on and blinks slowly. Is this normal? I wired everything as directed. Curious if someone can confirmed. Thanks
Tags: None
Completely normal. Your oil pressure is at zero with the engine not running, and that trips the check engine light.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
