Is your ProSport 12 battery charger not charging properly? Try the fix below.
Tools Required:
1. Large Flathead Screwdriver or coin
2. Diagonal cutters, Metal File or Sandpaper
Time Required:
Approx. 5 minutes
1. Disconnect AC power from the charger.
2. Confirm all charger cables are connected correctly to batteries.
3. Remove the programming cap from the wire end of the charger’s end cap using a screwdriver or a coin.
4. Reconnect AC Power. At this point, you should have the following LED’s
a. Blue AC power LED
b. Green Battery type LED (Gel)
c. Red Flashing Analyze/Charge LED
** If you only see the Blue LED, please contact your dealer for warranty replacement.
5. Disconnect AC power.
6. Programming cap alteration:
a. Using a metal file or sandpaper, remove approximately half of the material from the unthreaded portion of the programming cap.
** Approximately 1/8th inch of material will be remaining.
7. Ensure there is no debris in the programming cap hole, or on the cap itself, and reinstall the programming cap.
8. Reconnect AC Power. At this point, you should have the following LED’s
b. Red Battery type LED (Flooded/AGM)
** If you reencounter the issue, remove more material from the unthreaded portion of the programming cap until the charger is functioning properly.
** The charger must reset to register the correct position of the programming cap.
** The charger is now functioning properly and will follow the operation outlined in the manual.
Tools Required:
Time Required:
Approx. 5 minutes
