Loose Throttle Lever
  • ToolBoy
    • Jul 2006
    • 22
    On my 95 Nautique, the throttle lever, when pushed forward, does not stay put when I let go of it. I slips back to a 1000 RPM position. Only when I get up to 3000+RPM does it stay put.
    Is this normal?
    Is there a way to tighten it so I can pull at 2000 RPM and not keep my hand on the lever the whole time?
  • Roy
    • Jun 2005
    • 28
    RE: Loose Throttle Lever
    Yes, this is normal and configured for safety, add Perfect Pass.
    • Fonseca
      • Apr 2006
      • 35
      • Portugal - Castelo de Bode
      see the thortle lever brake. Is a screw behind the lever. If you tighten it you will get more brake
      • nms1991
        • 477
        That style of control is made by morse and there was no friction adjustment in that style but you can stretch the return spring on the carb a little to aid in that.
        • Roy
          • Jun 2005
          • 28
          Expanding on the factory specs is always a "bye bye to insurance move"
          Buy a new cable, add Perfect Pass or best yet if possible, update the year of your boat.
          If your requirements exceed your present position, sell and buy what is nedded if visible.
          Best wishes
