With all of the stuff now in the hull of the G's, getting a wrench on the T-handle drain plug can be really tough if it is to tight to take out by hand. I have searched the internet and I can't seem to find a tool to make this easier. It would seem someone must have made a slotted socket that can slide over the T-handle and spin out with a socket wrench. When I finally give up on google I turn to PlanetNautique for help. Let me know if you have found something.
On the rare occasion when mine is too tight to remove by hand, I just use a pair of pliers (or anything that can give a little more leverage), and grab the top of the T with those.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I keep a cheap tool kit in the boat, and in that is a stubby little adjustable crescent wrench. It's perfect for that, and incidentally good for battery terminals as well, because it's short, and the handle is rubber coated, so you really can't slip and end up shorting the battery... not that I've done that...
The only advantage of the adjustable crescent over pliers is that it's less likely to gouge the T-handle and make a sharp spot to cut you in the future. Otherwise, all the same.
Originally posted by pfield2jay View PostAgree that it shouldn't take much and that really it should never get that tight, but surely someone has created a cool tool to help in desperate times....
A water shut off tool would work. It’s cheap and can pick up at any hardware store.
https://www.acehardware.com/departme...E&gclsrc=aw.ds
