I have a 2011 210 and the check engine light has come on. Temp and oil pressure are good and I cannot find out why it is on all appears normal. Any ideas???
There are only two things that can set that light off -- the switch for low oil pressure or the switch for high engine temperature.
There is a sensor and a switch for each. The sensor feeds the gauges, and the switch trips the light.
You need to figure out which switch has failed, and replace it.
You can figure it out by disconnecting one and seeing if the light goes out with the engine running. If so, you found your bad switch. If not, try the other. Disconnecting the bad switch will allow the light to stay out until you replace the bad switch.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
