Hello,
I dewinterized my 2004 SV211 TE and no gauges turn on.
So i checked the Faria gateway box and there is zero water in it, looks completely clean. Reattached all wires and still nothing changed. I then checked dash wiring all seemed perfectly fine. Just to be completely sure i did check with a voltmeter and positive reads on all 4 pins and also checked between each gauge still positive reads. I then disconnected all and just connected the speedometer and nothing. Then i tried with the oil pressure gauge just to make sure it was not the speedo gone bad but also nothing.
I just cannot figure out what might be causing this issue. it seems unlikely that all guages fail the same winter? I also dont get why there is no light og digital display when there is clearly voltage going to the gauge?
Everything else on the boat is fine, just my dash that is dead.
Help very much appreciated!
TIA
TIA
