I have a 2003 Ski Nautique 196 that is cranking but will not start. I have checked the 3 fuses in the main fuse box and they look good, I have replaced all 8 spark plugs, ensured the boat is in neutral, the lanyard is on the kill switch, and charged the battery to a full charge. Not sure where I should go next with this issue. Any recommendations are appreciated.
When you turn the ignition on (before starting the boat), do you hear the fuel pump run for a few seconds?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Yes, the fuel pump does run when I turn the electric on. I replaced the fuel pump last year. Also, for background, the boat ran perfectly well about 10 times so far this year. We took about 20 ski sets with no problems prior to having this issue one day when we went to ski.
Run a test to isolate if a fuel or spark problem.
Posted via phone. Sorry for the tpyos.
Bellevue WA
