Put my 2015 SAN 210 back in the water for the season and has run fine a few times under load surfing with full ballast and just boat-riding at speed. This morning, we went for a slow coffee cruise at idle the whole time and it came up with Warning 1415 and 1416 - Exhaust manifold temp was high. Water appears to be flowing OK through the inlet filter on visual inspection, but the fact that both sides are coming up with the error makes me think its low water flow out of the sea water pump at low rpms/idle.
Have a new pump impeller on order, (but have not inspected it yet). Will replace that and see if it helps.
Other posts talk about a firmware upgrade for the 2015 PCM boat, and that these warnings may be a false alarm, so wondering if anybody has details about that.
