Boat starts once a day with key only when it’s cold
  • Aj1253
    • Apr 2020
    • 5
    • Bonney lake
    • 97 ski Nautique
    I just replace the Starter solenoid Boat fired right up with the key on. Took it for a drive came back turn the boat off and now the boat will not start The boat will not start unless I bypass the starter solenoid.
  • Peter6000
    • May 2017
    • 168
    • northern Virginia
    • 1999 Ski Nautique
    What engine and yesr?
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    • Aj1253
      • Apr 2020
      • 5
      • Bonney lake
      • 97 ski Nautique
      It’s a 96 Sport nautique. With a GT40
      • Peter6000
        • May 2017
        • 168
        • northern Virginia
        • 1999 Ski Nautique
        Check these: neutral switch on the transmission and then emergency pull switch if I remember right both are in series and supply ground to the starter helper relay.
        They ignition switch supply +12 in start podition.
