We have a 2017 G23 with the white LEDs for the cupholders and interior lighting. Wanted to see if anyone has found a kit or a way to upgrade to the multicolor LED lights and if they could be controlled by the dash screen? Would also be interested in the same for the transom lights
Originally posted by gpetry View PostWe have a 2017 G23 with the white LEDs for the cupholders and interior lighting. Wanted to see if anyone has found a kit or a way to upgrade to the multicolor LED lights and if they could be controlled by the dash screen? Would also be interested in the same for the transom lights
Single color cupholder lights and such aren't too bad. You just get the the right connectors and can plug in. We added red cupholders to our boat that did not have the lighted cupholder option - the 2 conductor wiring is all there on some previous model years. https://www.planetnautique.com/vb5/f...stall-2016-g23
For multicolor lights you need more than the two conductor wiring to be able to control the lighting. So if this is not already installed in the boat you would need to run it everywhere.
I recall that perhaps on the newer boats that this wiring may not be installed if the lighting option is not installed.
