Reversible Pumps on Stock 2004 SANTE buttons
  • JAppler
    • Apr 2019
    • 167
    • FL
    I am wondering if it is possible to install new reversible pumps on the stock Nautique ballast buttons. Has anyone done this?
    Thoughts?
  • GeoffW
    • Aug 2018
    • 75
    • Saskatchewan
    • 04 SV211
    I'm doing this as we speak. Not impossible just a fair bit of work to layout and wire. Need a bank of 6 relays assuming you have the touchpad. Check my thread in the restoration area.
    • JAppler
      • Apr 2019
      • 167
      • FL
      Thank you!! What’s the name of it?
      • GeoffW
        • Aug 2018
        • 75
        • Saskatchewan
        • 04 SV211
        Try this:
        https://www.planetnautique.com/vb5/f...-sv211-project
        Planning to finish up the electrical drawings soon. I do drawings for almost everything so I can trace later anyways.
        • JAppler
          • Apr 2019
          • 167
          • FL
          Thanks, I thought I’d seen this but couldn’t find it again...
          • XBIGPUN66
            • Oct 2012
            • 456
            • WI
            We did this in my old 2004 Sante. It worked out great. We mounted the pumps on the inside of the back fiberglass behind the back seat in the port and stbd aft lockers.
            Ian S
            • scottb7
              • Aug 2011
              • 2198
              • Carson City, Nevada
              You have the aerator pumps now? My buddies have axis boats with aerator and i love that they are faster and you can tell more easily when empty as they empty over the side. I don't know why you would want to put effort and dollars into changing. And replacing an aerator pump once in a while is not big deal and pretty comparable to buying impellers.
