GT-40 idling not steady
  • richard
    • Feb 2005
    • 406
    • HK
    my 01 SAN GT-40 had 650 HR on it, it's power ful and funtion good, but have an issue idling not steady the RPM will range 650 -1000,and will shut down, especiaaly when engine hot , need press start button longer time to start it, but when engine is cool,start fast, also need advise to check ISC solenoid.
  • brian635
    Banned
    • Jul 2006
    • 13
    RE: GT-40 idling not steady
    i have the same boat, and the same problem...i added some fuel injector cleaner and it has seemed to stop the problem.
    • richard
      • Feb 2005
      • 406
      • HK
      I had use injector cleaner recently, but that don't improve the problem, thanks for your input.
      • Grant_West
        • 758
        • Redwoodcity Ca
        Try claning out the flame arrestor (that the screen attatched to the throttle body)
        spray some carb cleaner and air threw it.
        Also clean out the Air idle screen Its a metal screen that Air flow's threw while under Idle
