ASCO 8210G095 120VAC vs 8210G009 12DC
  • AdrenalineJunky
    • Aug 2019
    • 5
    • California
    • 2004 SAN
    I see that many folks here have upgraded their older Flow-rite (wrong) ballast valves and control cable systems with the ASCO 8210G095. This is a 120VAC valve. I read that they open in 3-4 seconds using the 12 VDC source from the fill switch on the dash and there have been no issues with them. I called ASCO and talked to the tech. He said that I need the 8210G009 12DC and it will open instantly in milliseconds as opposed to 3-4.
    I have not see mention of the ASCO 12V valves in any of the threads I have read through. Is there a reason why?
    It just seems like he right fit. Has anyone used the 12VDC in their setups?
    Thanks for the input,
    Mike
  • Stevemo14
    • Apr 2019
    • 691
    • Columbus, OH
    I just installed these.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I can hear them open with the button push and the pump turn on, but I have not had them in the water yet to test.
    • AdrenalineJunky
      • Aug 2019
      • 5
      • California
      • 2004 SAN
      Good point STEVEMO, Those valves are like 1/3 the price...
      Question for everyone else, what other valves are you guys using and have had success with?
      Thanks again!
      Mike
