Chaise Lounge gas shock upgrade?
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    Anybody have a better option than the factory replacement from Nautique Parts. Seems like they’re just too weak. I replace them every 18months it seems due to failure. I do t have the exact dimensions. , maybe someone can chime in.
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    Yeah, kind of constant struggle for me too. I sometimes use https://www.liftsupportsdepot.com/ but you have to figure out what you need.
    • SilentSeven
      • Feb 2014
      • 1867
      • Bellevue WA
      • 2004 Nautique 206
      If you can determine the model number, you can typically cross the gas lift into other more cost effective brands & suppliers.
      The two key items you need are length and lb rating.
      Bellevue WA
      • Paxdad
        • Mar 2013
        • 775
        • Cumming, GA
        • 2008 210 SANTE
        Second this.
        2008 210 SANTE
        • swatguy
          • 1631
          • 2008 SANTE 210
          From what I found on NP it’s a 10.5inch 30lb gas shock. I am thinking somewhere between 40-50lb upgrade
          • swatguy
            • 1631
            • 2008 SANTE 210
            Actually measured the shock. I have 8 3/8 end to end , 7 1/2 center line socket to center line socket . Compressed is 5 3/4 center to center . It’s the glove box shock which is a 20lb shock. Just wanted to clarify .
            Trying to decide if I should go up to 30lb or go 40lb? Any input?
            My first inclination was (2) 30lb and (2) 40lb. Give it a go. If 30 works and 40’s too strong I could split shocks.
            • swatguy
              • 1631
              • 2008 SANTE 210
              So I went with 30lb upgrades. Seems to work great at keeping the lounge in the upright position.
              Cart Items SKU Qty
              7.50'' LiftSupportsDepot SE075P30 LiftSupport With Ball Socket | SE075P30-W
              • louise
                • Sep 2020
                • 1
                • Netherlands
                Check https://www.gasspringsshop.com/ for more information
                • gonefishin5555
                  • May 2018
                  • 114
                  • SoCal
                  • 2017 GS22
                  Just want to add that I bought my boat used 1yr old and the glove box shock already didn't work. Finally got it replaced recently under warranty. The rear hatches pop up on me when I'm on the road I guess that good the shocks still work The latches are not up to standard. Someone at Nautique is failing at their job they need a shock and latch expert.
