Fuel pump not engaging when I turn key before engaging starter.
  • Moss
    • May 2020
    • 2
    • Eatonton GA
    • 1997 Ski Nautique GM EFI small block
    Normally comes on before engaging starter. Mine is not coming on and will not start? 1997 Ski Nautique GM EFI small block. Please I need help fixing or replacing? Thanks Moss
  • MTRBTR
    • May 2012
    • 485
    • MT
    Start at the battery and check every connection. I had a 97 sport and all it was was a loose connection.
    2006 SV 211 (Sold)
    97 Sport Nautique (Sold)
    89 PS 190 (Sold)
    75 MFG (Sold)
    • Moss
      • May 2020
      • 2
      • Eatonton GA
      I will thanks dude!
      • wtrskrs
        • Feb 2019
        • 50
        • CA
        • 1997 Ski Nautique Previous: 1996 Ski Nautique bought new, had for 22 years, great boat!
        So, when you have the engine cover open, you don't hear the fuel cell pump that normally runs for a second or two when you turn the ignition on, correct? Along with checking all connections, I'd get a volt meter, unplug the connector to the fuel cell, and see if you have voltage briefly when you turn the key. If you do, you've got an issue with the fuel cell pump (although they rarely go out). If you don't have voltage, then as mentioned, check all connections. There is a jumper you can use on the connector by the ECM / breakers that allows you to turn the pumps on manually. The info is in the GT40 manual. I can look to see if I documented anything on which pins to jump to turn the pumps on. If you jump the pins and the pumps work, but they don't when you use the key, then it's a connector, wiring, or a bad ECM.
        • wtrskrs
          • Feb 2019
          • 50
          • CA
          Okay, I found what I was looking for. You jump from the pin to ground to start the pumps. The older picture shows the jumper from the pin to ground. The newer picture is a better shot of the connector.
          • wtrskrs
            • Feb 2019
            • 50
            • CA
            Okay, now that I look at both pictures, the newer picture was somehow flipped; the image is backwards. The correct jumper for fuel is the one that is closer to the other connectors. See the slope at the top; it is the steeper slope. Attached are pictures I just took. One with the jumper (my thumb is closest to the fuel jumper connector). The other one is the housing that holds this jumper plug. Slide it straight up to remove the whole thing, and then pull this connector. You might be able to pull the connector out without taking the housing off, but I didn't want to yank on the wires so removed the housing from the metal frame first.
            • mpost
              • Jun 2007
              • 139
              • Monticello, MN.
              • 98 SN GT40
              Originally posted by wtrskrs View Post
              So,The info is in the GT40 manual. I can look to see if I documented anything on which pins to jump to turn the pumps on. If you jump the pins and the pumps work, but they don't when you use the key, then it's a connector, wiring, or a bad ECM.
              Not sure if this is going to work for him. As stated he is running a GM engine, not a GT40.
              1998 SN GT40
              84 2001 Ski Nautique (sold)
              Monticello MN.
              • wtrskrs
                • Feb 2019
                • 50
                • CA
                Yeah, I noticed that after I sent all the pictures. However, didn't all MPI engines from PCM at that time use the fuel cell? If so, there's a chance that it would be wired similarly..
                • gun-driver
                  • Apr 2011
                  • 132
                  • Pittsburgh Pa
                  • 1985 Ski Nautique 2000 Sport Nautique
                  Check your Safety lanyard switch, if that’s not engaged the pumps won’t run.
