battery charger question
  • kylant
    • May 2010
    • 538
    • Lake Tahoe
    I just pulled my boat out of storage. I believe the batteries were left connected by the winterizing dealer. I have the onboard charger.
    Do I just plug the charger into shore power to charge the batteries?
    How does this thing work?
    thanks
  • Paul W
    • Oct 2010
    • 45
    • Lower Fox River IL
    • 2017 SAN230 Coastal Edition
    Connect the batteries and then plug in, its a trickle charger and will top off the batteries.
    • paticus
      • Sep 2019
      • 80
      • San Jose CA
      • 2019 Super Air Nautique 230 | 1998 MasterCraft Pro Star 205
      The onboard charger (assuming it's the factory ProMariner ProSport) should charge them back up. The front panel should have some indicators that will reflect the state of the battery. So yes, plug it into 120v power on shore, and it will take care of the rest.
      • kylant
        • May 2010
        • 538
        • Lake Tahoe
        thanks
        yes it is the factory installed charger
        • MLA
          • Dec 2009
          • 1312
          • Lake Wylie NC Area
          With a master battery switch, there is actually no need to physically disconnect the batteries. Turning the switch off disconnects the B+ from any loads, except maybe the auto bilge on some boats/models.
          If the boat lives where there is access to an AC receptacle, its good practice to use the on-board through the off season, rather then just in the spring. Its hard on batteries to sit with a low state of charge, especially in regions where the temps get low.
