New to the forum and just picked up a 2004 Air Nautique 226 TE. Pretty excited about the boat, a big upgrade from my 97 Mastercraft Prostar 205. The boat only has 220 hrs on an upgraded ZR409 motor and is pretty clean overall.
That being said, there are a couple issues, and I've done a bit of searching, but if anyone has any additional input it would be appreciated. The first thing I need to resolve, the front right bolt point(upper to lower) on the tower has a lot of play. I haven't had a chance to pull it apart to compare one side to the other, but are there some kind of bushings in there that wear out? If so is there a good source for these?
Second issue is the port-side hard tank is leaking above 3/4 full. I filled the tanks full and closed all the valves and could see the water running from the port side compartment into the engine bay. It seemed to stop at about 3/4 full on the gauge. It looks like my best option is to remove the hard tanks and replace with some bags. I was looking at the Wakemaker plug and play bags for the rear. They only list a 400lb bag for the port side, and 720lb bag for the starboard side. Is this my best option? Everyone in my family surfs the port side so I'd like to get more weight on that side if possible. Is 400lbs the best I can do with the walk through? Any other advice on setting it up to be surfable is much appreciated. I do have a wake-shaper as well. We will also be wakeboarding tubing and doing some recreational skiing behind it for what it's worth.
