Trigger wheel location?
  • dba4life
    • Sep 2004
    • 223
    • Raleigh, NC
    Hello
    Trying to finally fix an annoying cold start issue. Was told to check the wire connections at the "trigger wheel". Where is that??
    Issue:
    Dear Kevin,
    Check the wire connections at the trigger wheel, and at the TBI computer. Look for any oxidation or corrosion.
    Thanks,
    Vince Dougherty
    Ski Dim Service Mgr.
    -----Original Message-----
    From: KEVP (Kevin Potter) [mailto:KEVP@novozymes.com]
    Sent: Monday, August 14, 2006 8:11 AM
    To: skidimcustservice@sc.rr.com
    Subject: Ask In-House Experts
    Hello
    I have a 1994 Sport Nautique. 5.8 PCM ProBoss EFI with the protec ignition system. I have Perfectpass WB pro on the boat (v6.4)
    The issue I am having is that the motor will not fire the first start of the day. Once it is started she is good for the rest of the day. The injectors are on top of the motor just below the air filter. When trying to start I can see no fuel is getting pumped in. All I need to do to start is to spray some starting fluid into the air filter and then she starts without hesitation.
    Where do I start?
    • 2908
    RE: Trigger wheel location?
    Start here:
    http://www.planetnautique.com/index....tit&lid=22
    Seriously, the GT-40 is one of the best documented motors, this manual is like the GT-40 bible. Download it, print it and put it in a binder with your other boat service stuff.
    • nms1991
      • 477
      Sorry MIKESKI but the repair maual you gave him is not for his motor he has a tbi motor not a mpi motor. The trigger wheel is in the front of the motor and it is black and it has PCM cast into the cover. Just a odd question but how old is your battery and what type of battery is it? like a deep cycle battery or a cranking battery?
      • dba4life
        • Sep 2004
        • 223
        • Raleigh, NC
        Hi
        I do have the TBI EFI 5.8 Proboss. My understanding is that it is a different animal then the electronics that is on the Gt40. However the motors themselves are the same. Just the electronics differ.
        I have an Optima Blue top D34M. I am getting 12v at the back of the alternator with the engine not running.
        • dba4life
          • Sep 2004
          • 223
          • Raleigh, NC
          I checked the connection at the trigger wheel. The electric connector looks fine on there. No corrosion. I took the black cover off but that just revealed a metal disc. No wires.
          • darrel409
            • Jul 2004
            • 566
            • San Dimas, So. Cal
            PM or contact DavidF over at CorrectCraftFan, he has alot of experience with the tbi motor.
