Please help, 2006 PCM Excalibur 330 5.7 will not start, starter disengages before the engine starts and just spins (whines). Starter will disengage after one or two cranks. Has new battery, new spark plugs and new fuel filters. Was hoping to run into someone that may had the same issue. Thank u
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
You may possibly have lost a tooth or two on your flywheel. Let's hope not, but if the starter loses connectivity to the engine, that's the first thing that comes to my mind.
Next time it happens, you might try removing the starter and looking at the spot in the flywheel where the starter gear connects, and see if the flywheel is missing a tooth there.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I can't remember if these starters are the same, but the bendix might not be keeping the starter gear engaged with the flywheel, therefore causing the 'whine' or spinning. Might need a new starter.. And while you're at it, probably replace the cables. imoLast edited by shag; 05-23-2020, 01:18 PM.
The solenoid on the starter is what pushes the bendix onto the flywheel and should hold it there as long as the key is in the start position. Could be just a bad solenoid or loose/corroded connection there.1998 SN GT40
84 2001 Ski Nautique (sold)
Monticello MN.
