2004 216 OEM Battery Size?
  • redelf75
    • Sep 2003
    • 767
    • NYC
    Does anyone know the group size for a 2004 216? The manual doesn't list it, my boat is not with me so I can't even measure the battery compartment. In my research I think Group 65 is correct but I know many people use the blue top Optima which is 34. I need to know what to buy by June 1 because I'll be going to Maine then and will have to quarantine for 14 days.
    So looking for original size, largest that will fit or compartment dimensions including height.
    Thank you.
  • James
    • May 2007
    • 151
    • Indian Wells, CA
    I will check the battery in my 2006 216 in the am tomorrow and let you know. My battery compartment is in the floor immediately forward of the pylon. I am not 100% sure but I would bet your ‘04 is the same.
    • James
      • May 2007
      • 151
      • Indian Wells, CA
      Since new I have been using Interstate Group 34. I have recently purchased a new Interstate from Costco, Group 34, 800 CCA, 1000 CA, 110 RC Item # 850241. It is equivalent to Interstate MTP-34 from the Interstate retail stores at a better price. My PCM manual recommends a minimum of 650 CCA for my Excalibur 330.
      • redelf75
        • Sep 2003
        • 767
        • NYC
        Thank you James and sorry for the late reply. I ordered an AGM size 34 from Advanced Auto Parts. That should work fine I hope.
        I had some login issues that Jeff fixed for me - thanks Jeff.
