The rear cooler on my G23 came separated from being overweighted with cold beverages and rough water. It appears to be adhered with a hard epoxy. Does anyone know what Nautique uses? The other issue, it does not seem like I will be able to remove the loose cooler to sand and prep for glue based on what I am seeing. Does anyone know a trick for removing the cooler without doing some major removal of other components? Any info or guidance would be helpful and greatly appreciated! Boating season is here and that rear cooler is soooo convenient while swimming
