2015 G23 ballast pump impeller ?
  • agouge888
    • May 2012
    • 102
    • Tennessee
    • none
    Gettin ready to change my 3 ballast pump impellers on my 2015 G23. I’m guessing these take the Jabsco Ballast King Purple impellers? Do they require an o-ring to seal them? Also...what type of lube is recommended? Will vasoline work? I didn’t want to buy the kit that comes with impeller, grease, etc if I didn’t need the o-ring and grease.
    Let me know,
    agouge888
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    I would NOT think you would have the "ballast king" pumps in a 2015, but maybe all the impellers are interchangeable. Someone who knows more can maybe respond.
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      Yea, that's the correct impeller for the Jabsco. Nautiqueparts says they're "pink." https://www.nautiqueparts.com/produc...ler-pink-2016/
      So you can use grease, Vaseline, whatever. But for the o-ring, it just depends on how risky you want to be. If you get all three replaced without breaking an o-ring, you didn't need them. If you break one and are off the water for several days waiting for an order to come in, you needed one (or more).
      -Charles
      • agouge888
        • May 2012
        • 102
        • Tennessee
        • none
        UPDATE! Ok...I checked my pumps and they are NOT the Ballast King pumps Like I first thought...so my mistake. All three pumps are in fact the Jabsco “commercial water puppy” pumps Model 18670-6127 which take the lime green impellers. Got them ordered for 20.00 ea.They are on Amazon and come with the o-ring and grease.
        thanks for the help guys.
        agouge
