Windshield upgrade and Wavefront addition to 2018 G23
  • StormTrooperZ28
    • Aug 2018
    • 62
    • Petaluma, CA
    • 2018 G23 Black and Green XS7 Package
    I have two questions on upgrades I want to do to my boat.
    First one is does anyone know if you want upgrade your windshield on the boat. I have a 2018 G23 with the low model stock windshield. I really like new 2020 windshield or even the design package windshield for my model year. Can this be done
    Second is since I added a new sub amp I have 2 channels open on my 8 channel JL amp. Does Nautique or JL sell the wavefront pods separately so I can add that to my boat?
    Thanks for any input on this
    Matt
  • Miljack
    • Dec 2004
    • 1616
    • Charlotte, NC
    • '08 230 TE ZR6
    I have removed an older windshield ('99) and while it's not easy, it's also not a huge deal. Start by removing the lower weatherstripping on the outside of your windshield base (right above the deck). You will see the screws holding the windshield to the deck. Remove the "stands" or props near the walk through and you should be able to lift the windshield off. Remove the walk through center section first.
    As far as purchasing the windshields, they are available but very pricey.
    I'm interested in the JL Wavefront mod too, while the windshield is off is the time to do it for sure. Maybe a member could get a pic of the housing from underneath the observer's seat for you.
    2008 230 TE-ZR6
    • Rbt
      • Feb 2019
      • 24
      • Utah
      • 2018 G23
      I added two 1 inch tweeters on each side of my dash. I removed the windshield and used a hole saw to drill them and it sounds great.
