2007 SANTE stock clarion stereo wiring diagram
  • Jbousman88
    • Oct 2018
    • 54
    • Indiana
    • 2007 Super Air Nautique 220 w/ 6.0 ZR6 PCM
    Anyone able to point me in the direction of the stock 07 SANTE wiring diagram? Want to switch my amps out for some more power to my tower speakers. Possible do a separate one for the sub as well. Are the speakers in the boat ok or do most swap these out?
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    I know the smaller 2-channel amp drives the sub and I *think* the tower. Everything else is on the 4-channel. You can take a 9-volt battery and attach it to each pair of speaker wire to see which speakers each pair of wires goes to (the speakers will make a “pop” sound). The battery also tells you polarity - if the speaker “pops” outward, you have it wired correct, if it pops inward, you reversed it. Now, on a boat in the open air, I don’t think you could tell a difference with reversed polarity (and it won’t hurt anything) but if you want to do it right...
    • jkallen21
      • Jan 2013
      • 399
      • United States
      Correction - the 4 channel drives the subs and the non-tower speakers.
