Either I have a cracked core or the hose is disconnected on my heater. I know from the leak it’s somewhere in the dash but I can’t figure out how to access it. Anyone no what the access point is?
Before you pull off the bow seat cushion. It is easy to pull off the mounting flange of the hose outlets. Remove the flange, gently pull the hoses out as far as they will go and inspect the hose inside the hull with a flash light. They can be cut or damaged and the leak is inside the hose section hidden inside the hull.
