I recently purchased a 2014 g23, upon the maiden voyage, I could not get any wake out of the port side. The starboard side looks great, but no push at all from the port. Has anyone experienced something similar? I ran the recommended electric diagnostics and there were no tripped circuits. It seems that the NSS is not engaging at all on that side. Any help would be appreciated.
If NSS is not deployed there will be no surf wave just white wash like the image below.
Are you setting NSS=0 and NCRS = 3 - 5? NSS nonzero will usually result in a wave but it will roll over the top into a surfable but washy wave.
Thanks a ton for your response. Yes I had the NSS at 1, the NCRS at 5. Full factory ballast. Same setup on the starboard side works great, as speed approaches 10.8 wake grows and cleans up with no issue, port side not so much. Is there a way to see if the nss is engaging while on the trailer? Once again really appreciate any advise.
You will need to contact the dealership. They have a code that can activate NSS in test mode. Also go into System in LINC to see if you have any NSS faults stored indicating an error.
When this happened to us it was a failed lenco actuator
Ian S
Try swithing to starboard, let it form, then switch back to port while still going. This happens when one nss fails to go all the way back in. It may correct by switching sides then switching back.
Originally posted by greggmck View PostYou will need to contact the dealership. They have a code that can activate NSS in test mode. Also go into System in LINC to see if you have any NSS faults stored indicating an error.
dont forget the nss activates the opposite side you are trying to form the wake...2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
