Awareness Camera Issues
  • Skipdawg316
    • Sep 2014
    • 20
    Does anybody know how the awareness camera wire travels between the tower and console?
    Mine has been flickering for a bit and finally went into a blue screen. I understand this means it’s been disconnected.
    Want to check the connections, but can’t figure out where they are. Been searching around on the web but nothing seems to call out the awareness camera wire and connections specifically.
    BTW, it’s a 2017 G23. Thank you for any help or ideas.
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    It should thread through the tower on the Starboard side.
    -Charles
    • Skipdawg316
      • Sep 2014
      • 20
      Thank you. Is there an easy way to get access to it from the base of the tower? I’ve been poking around and it all seems sealed...
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        If you look under the tower leg where it hits the boat there should be a porthole with a cover over it. A couple of screws hold that cover on.
        • Infinity
          • Sep 2017
          • 730
          • Lake Norman - Denver, NC
          • 2014 SV244 w/ ZR409
          Have you checked the connection where it plugs into the video input at back of the screen? Maybe it vibrated loose or has some corrosion...
