Has anyone else experienced the rear locker hatch popping open while trailering? I’ve tightened all the screws but it seems to be happening more and more frequent. For now I’m just running an elastic rope over the top but am concerned with it leaving a mark on a long haul. It’s a GS22. Thanks.
Certainly a warranty issue. Let the dealer fix it.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
yep. same here.
I have had the grommets replaced under warranty and there is a redesigned bracket. I installed this the other day. warranty, drop shipped from Nautique
https://correctcraft-my.sharepoint.c...FField%20FixesLast edited by kylant; 06-17-2020, 06:13 PM.
I have a new 2019 GS22 and am experiencing the same thing on BOTH hatches. It feels a little weird cruising around looking like the batmobile with wings. Did anyone have a successful resolution to this? I currently put a bunch of electrical tape around the pegs and it is holding. Its not a long term fix, but will do until it is fixed under warranty.
Originally posted by LKAhornz View PostI have a new 2019 GS22 and am experiencing the same thing on BOTH hatches. It feels a little weird cruising around looking like the batmobile with wings. Did anyone have a successful resolution to this? I currently put a bunch of electrical tape around the pegs and it is holding. Its not a long term fix, but will do until it is fixed under warranty.
the brackets seem to keep the hatches closed even without “snapping” them into the grommets
is the new bracket kit, a complete change?....or was it because the black rubber grommets were new in the kit. I am having difficulty getting my dealer to move quickly on the warranty change. if i need to, i will swap the grommets for now. its quite frustrating driving around with the hatches popping every 3 secondsand the electrical tape solution is no longer working.
if the kits is new...does anyone have a link to a website that might sell it?
Originally posted by LKAhornz View Postis the new bracket kit, a complete change?....or was it because the black rubber grommets were new in the kit. I am having difficulty getting my dealer to move quickly on the warranty change. if i need to, i will swap the grommets for now. its quite frustrating driving around with the hatches popping every 3 secondsand the electrical tape solution is no longer working.
i posted the link above.
The link above is to a sharepoint site that I can't see. Please repost the site for the bracket retrofit.
is it this one? https://www.nautiqueparts.com/produc...r-catch-boats/
or this one? https://www.nautiqueparts.com/product/hatch-slam-latch/
I have the same problem I just don't tow far enough to worry about it
With the dealer replacing the hatch brackets under warranty we continued to have issues with the hatches coming open while trailering or on the water. I ordered and installed the upgraded plunger catches from Nautique parts along with 25 lb gas shocks. The plunger catches are tight and the gas shocks have just enough force to open the hatch once you pull up on them. No more issues with the rear hatches coming open.
Nautique parts. https://www.nautiqueparts.com/produc...r-catch-boats/.
The gas shocks were ordered from Maxim Hardware.
2 x Master Lift ML36 Gas Spring () = $36.28
a) Spring Force Amount 25
Rod Dia (d): 0.312
Cylinder Dia (D): 0.75
Stroke (A): 7.0
Extended Length (L): 17.2
Compressed Length (CL): 10.2
End Detail: 10mm
Originally posted by BigDaddyStrick View PostWith the dealer replacing the hatch brackets under warranty we continued to have issues with the hatches coming open while trailering or on the water. I ordered and installed the upgraded plunger catches from Nautique parts along with 25 lb gas shocks. The plunger catches are tight and the gas shocks have just enough force to open the hatch once you pull up on them. No more issues with the rear hatches coming open.
Rod Dia (d): 0.312
Stroke (A): 7.0
End Detail: 10mm
