Decode of CAN message PGN 127489 Engine Parameters, Dynamic
  • mo
    • Nov 2019
    • 6
    • Denmark
    • SV211 LE 2005
    Hey,
    Does anyone here have experience with decoding the CAN messages on the GCP protocal used on 07-08 PCM engines?
    I have decoded most of the messages but the PGN: 127489 Engine Parameters, Dynamic is still a work in progress and i could use some help.
    Example data scanned:
    0xA0 0x16 0x00 0xFE 0x10 0xFF 0xFF 0x78
    0xA1 0x71 0x9F 0x05 0x29 0x00 0x0D 0xD0
    0xA2 0x09 0x00 0xFF 0xFF 0xFF 0xFF 0x00
    What i have noticed so far is that the first 8 bytes are probably frame identifier and the second 8 bytes of the first message the length of data. In case of the message above it has 22 data bytes after the data length which fits with the 3 messages acquired. Does anyone know the fields(bytes/bits) used in this messages and the resolution of the values?
    TIA
  • LipSnap Wakesurf Boards
    • Jun 2014
    • 7
    • Iowa
    • 2014 Nautique 230
    Can you provide all the messages? I believe I have a few of them decoded but at least one isn't making sense. Having some engine data along with the messages would be helpful for verification.
    Coolant Temp, oil pressure, voltage, engine hours, etc.
    • mo
      • Nov 2019
      • 6
      • Denmark
      • SV211 LE 2005
      Hey,
      Sorry for the late response I do not have tons of time for this little hobby project
      I have decoded everything except the manufacturer proprietary frame which is probably going to be near impossible without some form of documentation so any help is greatly appreciated!
      @LipSnap Wakesurf Boards The full list of CAN messages is quite long even if i just send you a few seconds of it, but if you still want it pm me your email and i can provide you the file.
      As stated before i got everything except the PGN: 61184 (hex: 0CEF1100) but i so no logical pattern and have zero documentation about it for the PCM engine
      • sinansozuguzel
        • Feb 2024
        • 1
        • Istanbul
        Hi also i have same problem with read data message for PGN 127489, I dont know how can i decode this can message. For example i want to read "Engine Load Percent" but i didnt decode the PGN. Help please Click image for larger version
