Does anyone have any validated information/testing that the Garmin Fenix watch has a longer Bluetooth range vs the Pebble watch? The reason I ask is because the 3.0 Surf Select model(uses Garmin) now has an antenna on it whereas the 2.0 module (uses Pebble) does not have an antenna. If the range is substantially better I want to jump from the 2.0 module to the 3.0 module.
Thanks
Thanks
