Hey dudes, was hoping I could get some suggestions.
my new-to-me 200-hour 210 was slipping badly in idle when hot. It required more throttle to engage the transmission from neutral.
I checked the fluid and it appeared to be too full, so I did a fluid change even though it was just changed from its winterization in late 2019
this seemed to fix the issue initially but it has been creeping back.
do I have any other options? Performance is fine other than idle, reverse is fine, and the linkage seems fine.
im using ACE hardware brand DEXRON-III/MERCON ATF... could that by why?
coming from my 2003 SANTE (which I still have) it’s very puzzling and frustrating
thanks
thanks
