Tags: None
I’ve located the pre filter. Any suggestions on removing the end nut?Once I do, can I pull the filter element out, put the nut back on and just splice an in-line filter where it’s easier to get access to? I would use filter R080024A. Would I have issues with keeping the current low pressure fuel pump? It’s suggested to replace annually but it’s location makes it tough.
Thanks. I just barely finished replacing the factory pre-filter. Took me way too long and too many swears. Swapping it out will save my sanity.
