Transmission whine
  • Sepplino
    • Jun 2020
    • 6
    • Germany
    • 1994 Ski Nautique PCM 5.8 Pro Boss EFI
    Transmission whine
    Bought a 1994 Ski Nautique recently. The boat was sitting in a garage for 10 years and has only 300 hours. Unfortunately the transmission whines heavely.
    I also have another 1994 Ski Nautique (both are exactaely the same configuration) with almost 1500 hours on it and the transmission does not whine at all. Already checked the alignment of motor and shaft, but that is fine.
    Any ideas ?
    Thanks for your help, guys !
  • SilentSeven
    • Feb 2014
    • 1867
    • Bellevue WA
    • 2004 Nautique 206
    Same prop? There are some boating threads that discuss prop singing as a phenomena. Also, trust you've flushed the fluid? Outside of the noise...does it work ok?
    Bellevue WA
    • Sepplino
      • Jun 2020
      • 6
      • Germany
      Yes, same prop (ACME 422). Outside of the noise it works perfect. Yes, have changed the Oil (DexIII)
      • functionoverfashion
        • Jun 2017
        • 509
        • New Hampshire
        • 2003 SANTE
        Can you post a picture of both transmissions? I'm curious about something, if it's not too much of a pain.
        On my '89 there was a superfluous little hose that came up off the transmission. If you removed it, there was a terrible whine (I tried once, and had to fish mine out of a dumpster). I don't know if your boat would still have that, though.
