1992 SNOB Tripping 60 amp circuit breaker!
  • acemech
    • Aug 2006
    • 35
    • Ca.
    • 1992 snob red/black
    ok here goes,been lurking here awhile......
    The boat is a 1992 SNOB GT40 w/carb and pro-tech.Have had a intermittent problem with the boat popping the 60amp circuit breaker when shutting down after running at skiing speed.In the beggining(1995), it happened maybe once a season...if that, not a big deal.
    Just got back from the River, and on this trip it would pop the breaker after every run, but only when you shut the engine off.Tried letting it idle for a few minutes before shutting her down but still popped the breaker.All wires are tight on the starter and the breaker terminals.(in the past I associated the problem with wires which were just slightly loose on the starter solenoid?)The boat also will, on occasion, under throttle, hesitate for a tenth of a second but does not stutter more than for a fraction of a second.This boat is in perfect shape,450hrs, does not drip any fluids, and other than the above problem runs perfectly.(Does about 47mph spinning a 4blade OJ prop)
    Just replaced the plugs and drained the fuel out at the beginning of the season.I'm
    thinking maybe a voltage leak to ground,leaking spark plug wires,circuit breaker possibly weak,starter solenoid leaking to ground, but why only when it shuts down???
    If it was a ground leak, I would think the pro-tech would go into limp mode.
    ANY input from you folks here would be greatly appreciated.As of right now I'm
    gonna replace both breakers,spark plug wires and starter solenoid. this to me is a shot in the dark but kinda my only option at this point.(going to Naci. for the reunion in a few weeks no time to take in for service)I'm pretty capable with a volt meter so fire away your suggestions....Sorry for the long post.
    Thanks in advance!
    Ron
    1992 SNOB GT40 sigpic- 96 engine cover with converted hull hugger exhaust.
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    RE: 1992 SNOB Tripping 60 amp circuit breaker!
    I don't see how it could be the plug wires... but this is sort of a bizarre problem. Usually breakers don't pop when you kill it, they pop when you start. hehe. And you're sure it's happening when it's being turned off, not at some point during the run?
    It sounds like there are 2 wires that are touching that shouldn't be, and I would guess in the starter/solenoid area.
    Sorry I couldn't be of more help.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • acemech
      • Aug 2006
      • 35
      • Ca.
      Hey Larrry,
      Thanks for the input. Yeah I'm sure about the thing popping when I shut her down.The whole boat goes dark.In fact when she hesitates under throttle, it goes dead and the radio has to re-set etc.like I said it's only for a fraction of a second though, and it doesn't trip the breaker at that time, only when it shuts down.
      For some reason I'm thinkin' a high current voltage draw accross the solenoid, why I don't know.
      Thanks again,
      Ron
      • jthooker
        • Jun 2005
        • 68
        • Mansfield, OH
        Just a thought... Your ignition switch might be the culprit. Check the back of the switch to see if any of the connector posts are loose in the plastic to the point where they are making contact when they shouldn't.
        • surroundsound64
          • Jul 2005
          • 2147
          • Longview, TX
          Man, I was at a dealer today checking on a water hose and I ment to ask them if they had ever heard of this problem... but I forgot. I may be back towards the end of the week and if I remember I'll ask.
          You could always call a dealer though.
          2018 SAN 230
          1981 Ski Nautique
          Sold - 2000 SAN
          • acemech
            • Aug 2006
            • 35
            • Ca.
            Thanks again,
            I'll have a look at the ignition switch, anythings possible.
            Larry, thanks again for lookin' out, I've got a guy out here by the name of Bill Wilson, he's a **** good mechanic, used to call him Dr. Nautique.Can't seem to find his number though.....Maybe I'll put a call into the Dealer...
            Ron
